Main Forum => General Discussion => Topic started by: gandalf42 on April 04, 2023, 09:15:13 am
Title: Lithium batteries and starting the generator
Post by: gandalf42 on April 04, 2023, 09:15:13 am
So, I have been looking at upgrading to Lithium batteries and have everything figured out except for the requirements on starting the generator, which we would still use for the microwave. Folks stating specs say 450 cold cranking amps are required but anecdotally there are reports of no problems with just 2 100Ahr batteries (verses the 4+ the specs would indicate). I am trying to fit the batteries into the current battery compartment to make the change easier, so that limits the battery space.
My generator starts hard unless started daily so not wanting to risk damaging batteries.
My question is: If you are using lithium and the generator, what are your lithium battery system details: manufacturer, battery AHr, number of batteries. Any other related info you have gleaned on this issue would be appreciated.
Thanks!
..Mike
Title: Re: Lithium batteries and starting the generator
Post by: DKCruzser on April 04, 2023, 09:50:03 am
Two - 100 amp/hour Battleborn Lithium batteries.  We have had no issues staring our generator.
Post by: Funseekers on April 04, 2023, 04:16:54 pm
Same here..2 battleborn batteries @ 100 amps and no problem starting generator
Post by: donc13 on April 04, 2023, 04:18:56 pm
Cold cranking amps are not related to amp hours rating.
450 amps for 1 minute = 7.5 amp hours
Typically deep cycle and/or Lithium batteries are not rated in cold cranking amps
As a side note, I have always disconnected my house batteries over the winter but to exercise the generator, I simply started the engine, waited 20 seconds and then started the generator using only the engine battery (since the house batteries were physically disconnected).  I never had a problem doing that.
Post by: gandalf42 on April 04, 2023, 06:40:54 pm
DKCruzser and Funseekers: Thanks for your replies!
 **true, but you still supposedly need the amps and 100ahr lithiums are typically rated as 100A max (often 200A surge for a "short" time)**
**Also true but I just don't want to start the RV every time I want to start the generator.**
Edit: It is interesting and useful info that you can start the generator with the house batteries totally disconnected. This would cover the harder starts during the winter monthly exercising the batteries.  2o2
Post by: CalCruiser on April 04, 2023, 09:29:42 pm
Use the maximum continuous discharge current spec, not Ah or CCA. For lithium ion batteries  that’s limited by the internal BMS.
From the Battle Born manual:
"Multiple BB10012 may be mounted in parallel in order to increase the current capacity of the system. When batteries are mounted in parallel, the voltage of the system does not change, but the current limits are additive. For example, two BB10012 batteries mounted in parallel can deliver 200A continuously and 400A for 30 seconds. Three BB10012 batteries mounted in parallel can deliver 300A continuously and 600A for 30 seconds. Therefore, all cables and connections MUST be able to accommodate the high currents that can be delivered by the battery. Appropriate fuses and circuit breakers are also highly recommended to protect downstream components from current spikes and short circuits."
Post by: keelhauler on April 05, 2023, 06:52:19 am
Reply to GANDALF42
To start the generator using engine battery you must have the ignition on, you don't necessarily need to start the engine, but if you don't you are lowering voltage in that battery.
Post by: parkgt on April 05, 2023, 10:57:07 pm
The two SOK 206ah batteries installed in my modified battery compartment on our 2018 2552 start the 4K generator even when down to under 20% SOC.
They also run my AC or microwave running through a Victron inverter.
Post by: gandalf42 on April 06, 2023, 06:40:52 am
Thanks for your comment! Since the SOK's are not sealed, did you ensure the battery compartment was sealed or did you seal the batteries some way?
In modifying the battery compartment, did you just take out the drawer or ?
Thanks!
Post by: mikeh on April 06, 2023, 10:59:52 am
Mike----I hesitate to comment on this issue because I haven't yet made the move to lithium--so can't speak from direct experience.  However there are a couple of considerations to keep in mind just based on electrical reality that might factor into your decision.
I assume you have separated the generator starting current requirements into the brief "inrush" demand, and the actual cranking current needed for longer duration.  The CCA requirement specified by Onan (450 amps or whatever) relates to inrush--which on the Onan 4000 has been measured at about 350 amps but exists for less than 500 milliseconds.  Actual cranking current depends on battery voltage, but should run about 70-75 amps for whatever duration until the generator starts.
Also, the actual longer duration cranking current will depend on battery voltage under load (while the 70-75 amps are being pulled).  The DC starter motor is pretty much a constant wattage demand, so the more the battery voltage drops under load, the higher the current draw will be.  As I understand, lithium batteries hold much higher voltage under load compared to lead-acid (either flooded or AGMs).  Where a single lead-acid engine battery might drop to 10 volts or less under a cranking load (though the house battery bank shouldn't drop that low just cranking the generator), a lithium under the same conditions will hold 12 volts--reducing the actual current draw for the same power output.
These may be some of the reasons why, in actual experience, folks have no problems with their lithium setup handling the generator demand, even with lower state-of-charge.
Mike
Post by: gandalf42 on April 06, 2023, 11:36:14 am
Mike
Mike, No I didn't know this distinction and so, this info is very helpful. It clears up the specsmanship a lot. Thank you.
Post by: gandalf42 on April 07, 2023, 08:34:33 am
It is interesting that Battle Born Batteries in their FAQ imply their understanding of cold cranking amps drawn on their lithiums  is a measure of surge current over time:
"Can you batteries start my Onan generator?
Onan are one of the most popular generators on the market for RV applications. Most RVs and campers come equipped with a generator, and the Onan is compact enough to fit into most camper’s cargo spaces.
Onan Generators startup requirements typically run between 360 and 475 cold cranking amps. Although two of our batteries will almost always start your on-board generator, three of our batteries are an ideal match."
This comes from a company with one of the stronger discharge surge ratings: 200A for 30 sec.
That would equate to 400A for 2 batteries and 600A for 3 for 30 seconds, a conservative answer.
I am going to try and get a clarification on the spec and current requirements from Cummins.
Post by: donc13 on April 07, 2023, 04:29:33 pm
Just looked at the specs for the Onan 3kw generator.  It doesn't say the requirements for starting it, but does say that if you buy Onan's starter battery option, the battery they supply is a 460 cold start cranking battery at 0 degrees Fahrenheit.  BUT, with the ignition on, the lead from the engine battery goes through a 40 amp breaker and then to the generator starter.  That's according to Keelhauler's latest wiring diagram.
You need less than 40 amps to crank the generator.   And to me, that makes sense, because the generator engine is a single cylinder 4 cycle engine that really doesn't take much to crank.  I would not have a problem starting it with a pull starter.  I was able to start my 8 HP single cylinder 4 cycle snow blower by hand.
Post by: mikeh on April 07, 2023, 11:51:23 pm
Guys, for what it's worth the actual re-settable circuit breaker that Phoenix installed in the generator cranking circuit in our PCs is a 120-amp breaker.  You will find it installed on the back wall of the battery compartment along with the two big main fuses.  Again, while inrush current to the starter is significant, it's extremely short duration.  Once the starter motor is turning, current drops to a fixed stabilized value depending on battery voltage and ambient temperature for the duration of cranking.  As Don implies, this is not a large engine--actual rating is 9.3HP on the new 4K models.  This is essentially a lawn mower starter, and a small one at that.  I've seen cranking current stabilized at 70 amps on these starters, but that was on the larger Marquis Gold 5500KW unit.  The 4KW should normally be less.
Regarding Onan's requirements for starting:  The current Onan Installation Manual for the new MicroLite 4000 series states the following:
"Use rated cranking current as the basis for calculating battery cable size. Rated cranking current for these gensets is 180 amperes at 0 degrees F−18 degrees C. The cables should be sized so that voltage across the cranking motor terminals will be within 1 volt of the voltage across the battery terminals."
The "rated cranking current" is NOT the actual current that will normally be employed in cranking.  That is the target current to design the installation (cable size, etc) to support, just like the battery requirements are 360 Cold Cranking Amps above 32 degrees, and 450 CCA below 32 degrees.  Again, the circuit breaker that Phoenix put in the cranking circuit is 120 amps, so even under the worst condition your current draw would be appreciably under that.
Post by: gandalf42 on April 08, 2023, 12:18:58 pm
it sounds like Cummins/Onan has had the question come up before.
I looked in the installation manual for my model (QG 4000 KY-R) and I only see mention to size the cables based upon distance and using 1000ccA as a guide.
Based upon the numbers stated, one 100Ahr battery ought to be able to start the generator. Makes you wonder why Battle Born says 2+. It could just be a generic safe answer.
I didn't know they put the breaker at the back of the battery compartment. It can't be seen in mine as battery cable lengths only allow the battery slide out about 4 inches. It's good to know as I wondered where it was.
I did send a note into Cummins. It will be interesting to see if they reply and what they say.
..Mike
Post by: parkgt on April 11, 2023, 11:43:15 pm
Thanks!
box
I used Gorilla brand sealing tape around the seam of the case.  https://www.amazon.com/gp/product/B07HSKRYQW/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
Taking out the drawer would not provide enough space for the two 206 ah switches, fuses  etc.  I fabricated a new larger box.
 https://forum.phoenixusarv.com/index.php?action=dlattach;topic=4766.0;attach=7662;image
https://forum.phoenixusarv.com/index.php?action=dlattach;topic=4798.0;attach=7708;image
Post by: gandalf42 on April 12, 2023, 09:11:54 am
I had thought along these same lines.
Impressive box build!!  2o2 (Beyond my simple abilities!)
Thanks!
..Mike
Post by: gandalf42 on April 20, 2023, 10:14:42 am
I appreciate all of the info everyone provided. I sent a question to Cummins but they never responded.
The point of 350A for less than .5 seconds and then dropping to 75A provided by MikeH is very helpful.
Somewhere in internet land I saw where someone measured 280A on a 4KW unit.
This maps with folks stated experience of successful starts with various lithium banks:
2 Battle Born 100AHr: max discharge spec: 200A for 30sec. = 200*2= 400A for 30 sec.
2 SOK 206AHr: max discharge spec: 200A for 3 sec = 200*2= 400A for 3 sec.
2 SFK 300 AHr: max discharge spec: 200A for 2 min. = 200*2=400A for 2 min.
I haven’t seen any reports of a single one of these batteries starting a generator
The AMsolar webpage states that a single LifeBlue battery can start an RV generator.
LifeBlue 100AHr max discharge spec: 350A for 3 sec (> 400A for 4 sec will trigger an over current event)
This provides me with some options within the limits of the battery area and wanting both the heated batteries and Bluetooth.
Thanks again!  :)
…Mike
