Main Forum => Tips and Tricks => Topic started by: Ron Dittmer on May 18, 2021, 07:23:52 pm
Title: Adding A Propane Tank Shield On Our 2007 2350
Post by: Ron Dittmer on May 18, 2021, 07:23:52 pm
This has bothered me for 14 years.  I finally got around to making a shield for our propane tank that was always fully exposed to the rear tires as shown here.
(https://live.staticflickr.com/65535/51188424853_a86e24bea7_z.jpg)
I bought a truck mud flap from a truck stop during one of our vacations.
(https://live.staticflickr.com/65535/51188424913_159c694ffe_z.jpg)
I measured and cut out my shield, first with my table saw, followed with a large scissors for the detail work.
I used a generic perforated bracket for mounting it.
I used hardware I had around the house including nylon locking lug nuts.
Cost was only that of the mud flap which as I recall was around $25.
(https://live.staticflickr.com/65535/51189268925_f8c14f15ca_z.jpg)
I assembled it followed by a final fitting, then decided to adjust the lower-right area for improved clearance to the leaf springs and parking brake cable.
(https://live.staticflickr.com/65535/51188424688_816e19fb35_z.jpg)
Here it is installed and the project finished.
I screwed the perforated bracket up into and through the PC wheel well liner into the steel above it.  It wasn't too thick, the large screw was able to self-tap into it.  I got lucky, in that there was a large production hole in the thick hardened steel main cross frame to allow the screw to the far right to pass through it into the steel above.
(https://live.staticflickr.com/65535/51189268680_eaf02d258e_z.jpg)
(https://live.staticflickr.com/65535/51188975169_1db66fd6f0_z.jpg)
(https://live.staticflickr.com/65535/51188975134_ed0c0ae1e3_z.jpg)
(https://live.staticflickr.com/65535/51187503627_7ddd3316c1_z.jpg)
Title: Re: Adding A Propane Tank Shield On Our 2007 2350
Post by: Tarnold on May 22, 2021, 09:27:02 am
Did something similar.  If you have a tractor supply company nearby, they sell horse stall mat by the foot.  Works like your truck mud flap.
Post by: Ron Dittmer on May 22, 2021, 11:53:27 am
Ah!  Good tip.
Post by: Cropduster on May 25, 2021, 05:32:54 pm
Herr Dittmer,  Das ist hervorragend!
Thanks for the information and pictures.
- CD
