Main Forum => General Discussion => Topic started by: BruceClerico on May 14, 2021, 11:50:29 am
Title: What is this & where does it attach?
Post by: BruceClerico on May 14, 2021, 11:50:29 am
My wife & I have just purchased a 2013 PC 2910T & joined the PC Forum.  I have a couple questions for the "PC Veterans" out there:
1)  While going through the bays, I found a leather-bound bolster (see pictures attached) and cannot determine where inside the coach it belongs.  The dealer was also unable to help.  Does anyone recognize the item in the pics & can tell me where it reattaches?
2)  I am considering spray-painting the exterior of the bathroom skylight to reduce the heat-producing light entering the coach.  I plan to paint it silver or grey to match the other rooftop items.  Has anyone done this?  If so, what were your results?  What type of paint was used?
Thanks, in advance, for your help.
Bruce & Kitty Clerico
Orlando
Title: Re: What is this & where does it attach?
Post by: mikeh on May 14, 2021, 12:21:35 pm
Hi Bruce!  Welcome to the forum to both you and Kitty!
Can't help with your skylight question, since I haven't modified mine (and don't remember seeing past info in the forum from others about painting that).  Hopefully someone can provide some input.
The bolster you ask about is the insert that goes between your two pull-out foot extensions on your recliner couch to fill the gap if you want to use it for a bed.  After you pull out each foot-rest, insert the bolster into the space between them and it will fit in to fill the slot.
Hope you enjoy your new PC and don't be stranger on the forum!!
All the best,        Mike
Post by: BruceClerico on May 14, 2021, 12:32:41 pm
Thanks, Mike.  I knew there was a place for the bolster.  Just needed someone to point it out!  I appreciate the info.
Post by: CalCruiser on May 14, 2021, 12:53:23 pm
TOFTT  and try gray or silver Plastidip spray paint. If the skylight experiment doesn’t work it’s easy to peel off, no harm no foul.
