Main Forum => General Discussion => Topic started by: SILVERLINER on May 08, 2021, 08:38:36 pm
It's importance, specially if boondocking ,dry camping and more importantly prolonging the life of your batteries .
Most RV come with push button leds telling you battery capacity 1/3- 1/2- 2/3 -full or gauges that read actual volts, and or battery percentage." NOT ACCURATE " a shunt is needed at the battery on the ground cable for ACCURATE reading volts,amprere, amp hour,battery percentage, soc,rate of charge & discharge and more . Usually a very expensive add on (Victron gage) now theirs an inexpensive shunt gage available highly rated Aili battery capacity gage check YouTube/ Amazon. Very pleased with mine ,works great, easy-to-use and install.
Hi SilverLiner,
You are surely correct in that those LED indicators are the worst, and a simple volt meter does not provide an accurate reading of a healthy or unhealthy battery.
The Aili monitor you mentioned being sold HERE (https://www.amazon.com/AiLi-Battery-Monitor-Voltmeter-Motorhome/dp/B07CTKYFTG/ref=asc_df_B07CTKYFTG/?tag=hyprod-20&linkCode=df0&hvadid=343224601369&hvpos=&hvnetw=g&hvrand=14275330906469428909&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9021506&hvtargid=pla-578884262857&psc=1&tag=&ref=&adgrpid=70737352522&hvpone=&hvptwo=&hvadid=343224601369&hvpos=&hvnetw=g&hvrand=14275330906469428909&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9021506&hvtargid=pla-578884262857) is very interesting. I like it.
A volt meter does provide an "indication" as you become acquainted with the change in readings. It helps immensely to place it where you can't help but notice it.
Six years ago I installed a simple volt meter in my 2007 stove hood as shown. CLICK HERE (http://forum.phoenixusarv.com/index.php/topic,2234.0.html) if you want to learn more about it.
(https://live.staticflickr.com/648/21656677384_1b1ec7fd0f_z.jpg)
I also attached on the inside of the over-head cabinet door above the sink, this chart on what the reading indicates.
(https://i.stack.imgur.com/clBVt.gif)
The complaint with a simple volt meter is that the reading drops when things are turned on and rises when things are turned off. The fluctuations are what you become naturally trained to understand with time and experience.
The way we camp, we rely heavily on our battery reserves, most especially if running the furnace overnight without shore power. So the time it takes to fully charge our batteries with the generator is determined on the amount of drain, hence we do our best to avoid draining our batteries down too far between charge times.
The Aili monitor would seem to be a very nice improvement over a simple volt meter. Thanks for sharing that.
Silverliner, I agree with your post. I see on the numerous RV forums as well as chit chat with others you meet at campgrounds dead batteries seem to occur all too often leaving a person or family to an unpleasant camping experience. Many just take batteries for granted. Some probably don’t even know they have a battery or what it does. For those as you point out that camp without electrical hookup or store their RV unattended can quite often be mislead by the led or even the volt meter type gauge. Though these gauges can sometimes be better than nothing they can also be worse than nothing if one doesn’t understand the proper way to use them.
I installed a Victron unit in a previous pull type camper about 8 years ago and was very impressed with its usefulness. I moved it to my PC and found it very useful not only in determining how much battery power I had but how different appliances, etc. drew down the charge. I have also found it very helpful in troubleshooting electrical issues.
Just recently Victron came out with an updated unit that allows one to monitor status from your phone. I have now replaced my older unit with this and will be installing the older unit in my daughter’s RV. This is the model I just purchased and installed in my PC. [size=78%]https://www.amazon.com/Victron-SmartShunt-500AMP-Bluetooth-Battery/dp/B0856PHNLX/ref=sr_1_3?crid=3VEUSIMHO9W3W&dchild=1&keywords=smart+shunt+500+victron&qid=1620558435&sprefix=Smart+shunt%2Caps%2C188&sr=8-3 (https://www.amazon.com/Victron-SmartShunt-500AMP-Bluetooth-Battery/dp/B0856PHNLX/ref=sr_1_3?crid=3VEUSIMHO9W3W&dchild=1&keywords=smart+shunt+500+victron&qid=1620558435&sprefix=Smart+shunt%2Caps%2C188&sr=8-3)[/size]
It is cheaper as it does not include the meter but utilizes ones phone which I prefer. As long as one is in signal range (100 ft would be my guess) it is easy to access the battery status.
You can also push the button on your inverter to see what the voltage is. Or your solar controller if you have solar.
I have used the colored chart ( like Ron posted above) over the course of two Cs and two Bs (a long time) and a simple voltmeter. It seems to me that you become pretty aware of load and I intuitively seem to come out OK on battery usage and when to recharge.
That said, before we leave on a trip if we haven't used the PC in a few months, I check the voltage and then run the Fantastic roof fan and the bathroom fan for two or three hours and maybe a light or two as well. Then I check the voltage again after I turn all that off and let the batteries rest an hour or so and check the voltage again and compare it to the chart (which is taped to the inside of the battery compartment). I check the water level on the batteries monthly over the winter/storage months and charge the batteries then as well as using a battery disconnect switch. We have 300 watts of solar and that certainly helps the situation. I turn off the solar, off course, before I do the exotic, high tech "fan test". >:(
(exactly)
But for people who are not as mindful as you and me, that intelligent $45 monitor by Aili that SILVERLINER shared, seems to be a good investment. If only it could be mounted in plain sight as a constant reminder to the user. It is remarkable how quickly you can drain your batteries without realizing it, most especially on a rained-out day.
Have any of you used or have an opinion on the Renogy battery monitor shown here ? Im leaning towards this one and putting it in the wall beside the steps where the OE battery disconnect panel is mounted. My battery disconnect has been replaced by a PO to the standard red knob under the bed where i suspect the original disconnect solenoid was mounted and likely failed so they simplified it. I discovered this while figuring out why my panel seemed inoperable and think ill just leave that instead of making it back to original. So i dont need that panel and feel i can fabricate a trim piece to fix the renogy there and make it look nice and usable.
Ant thoughts?
I have that exact model. I haven’t used it yet, but it is mounted in the exact position you mentioned, by a previous owner.
I have a feeling that all of its parameters reset once you turn off the batteries though. I think you start with full batteries then set the capacity of the batteries as full, then the meter and shunt keep track from there.
Someday soon when I retire I won’t need to shut the batteries off and I will learn from there.
HAHA.....love it. Im trying to get all this set up for that exact reason....to retire. I still have a few years left before i can but its a goal im certainly looking forward to.
Excited for that day to arrive for you!
October 9 is my day 😊
I'm probably not the right person to reply here, as I replaced everything with Victron and lithium (800AH) and added solar (2.3KW on the roof & 800W on the ground), but here are my thoughts for what they are worth...
The invertors and convertors only last about 10 years. They either wear out from usage, heat or age... Plus or minus a few years... And your mileage will vary...
My invertor degraded to the point 1700 watts was its peak (no longer 2000W} and the microwave over heated it. The convertor was slow to charge my batteries and wasn't doing anything to extend their lives and its fan was extremely loud. .
So where am I going? I initially thought I would replace each box as it quit, but it's not easy finding equipment that is compatible with older stuff while also "future proofed" to be compatible with modern power technologies. And then I realized that if I didn't stick with a single brand I would soon have displays and buttons on every wall.
I was ultimately going to need to replace the AGM batteries again that year, as well as everything under fridge. My battery tray rusted out and the batteries dropped to the ground while I was adding water... That was the final straw, TBH. It was then I decided to make that big step. .
It's a serious question to consider. Continue with lead acid batteries and old technology, maybe another 3 years.. or switch to lithium/solar/modern invertor&convertor. I now have a single touchscreen on the wall. Full control also on my phone/laptop/tablet. Batteries that will last 10+years. The ability to boondock for a long as I can carry enough water. Oh, and no noisy fan keeping me awake at night.
I'm not suggesting to rush in and replace everything. But it was the right decision for me as I plan to retire very soon, travel a lot, boondock more often, do repairs less often and never maintain another battery.
Larry
I would not recommend the Renology because it's very hard to see the display and it doesn't Blutooth to your phone. I've had really good luck with : https://www.amazon.com/dp/B09W2H9FB1?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_11
