Main Forum => General Discussion => Topic started by: Bangorbob on April 09, 2021, 01:44:02 pm
Title: HWH Leveling System Tank Fill
Post by: Bangorbob on April 09, 2021, 01:44:02 pm
I finally found the reservoir tank for the leveling system.  Check the level.  It is low.  Question is:  how the heck are you supposed to fill when it has to be filled at the top and you have only about 2 inches-maybe?
Title: Re: HWH Leveling System Tank Fill
Post by: CalCruiser on April 09, 2021, 02:23:06 pm
Like changing the gear oil in a differential?
https://www.amazon.com/Slippery-Pete-Fluid-Quart-Bottles/dp/B07CX4XKFH/ref=asc_df_B07CX4XKFH/?tag=hyprod-20&linkCode=df0&hvadid=312632042117&hvpos=&hvnetw=g&hvrand=9527386222782286728&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=9031624&hvtargid=pla-571716055828&psc=1
Post by: Bangorbob on April 09, 2021, 04:19:17 pm
Thank you very much for the answer.  At the time I posted the original I just wasn't thinking.  At lunch I thought of how many times I have used a pump.  Gotta start thinking before typing.  Again thanks.
Post by: Barry-Sue on April 11, 2021, 04:18:28 pm
I cannot find the reservoir tank for the HWH system. Can someone give me a clue as to where it is located on a 2551.  A picture might help me as well.
Thanks
Post by: Barry-Sue on April 17, 2021, 03:45:32 pm
Where was your reservoir located?  It might give me a clue as to where to look.
Thanks
Post by: lmichael on April 17, 2021, 04:41:42 pm
Drivers side front of rear wheels across from muffler, black box, cap on top
Post by: fandj on April 17, 2021, 06:23:54 pm
I don’t have a photo in relation to the chassis but this photo shows the HWH tank with fill cap.
Sorry photo is rotated 90 degrees.
Post by: Barry-Sue on April 18, 2021, 09:55:39 am
SUCCESS-Thanks everyone, finally found it.  Took awhile because we kept looking from the drivers side and could not see it but coming at it from the passenger side it was easily recognizable.
Post by: Bangorbob on April 18, 2021, 10:36:14 am
B & S,  Sorry I didn't answer your question, but others did.  Glad this forum could help.
Post by: Ron Dittmer on April 19, 2021, 09:54:11 am
Boy the fancy leveling system surely looks complicated with all those wires and hydraulic lines.
Post by: Bangorbob on April 20, 2021, 09:09:17 am
There are a lot of things in life that look complicated but are nice to have.   HWH called me back yesterday and was on the phone for about 40 minutes walking me thru an issue.  Very nice company to work with.  Makes things less complicated when  a company actually has customer service.
Post by: 2 Frazzled on June 23, 2021, 12:58:06 am
I FINALLY found the hydraulic fluid tank for our jacks. It was my third trip wiggling around under the rig on sharp gravel so it feels like a big win. For those still hunting theirs, I had John work the jacks while I was under there and tracked the motor whine (saw a comment to do this somewhere on this forum). Add in several lights glowing red when I watched from the front driver area and I had a happy Eureka moment. Our set up has a welded frame attached to the left "beam" that holds everything up. It's behind our propane tank when looking from the driver's side. I was not tool equipped and it's hot here so one more painful exploration will be needed to determine if low fluid is our lazy jack problem. They do extend but then one or two will sink at random times.
Post by: mikeh on June 23, 2021, 01:27:25 am
Holly--
Certainly worthwhile to check the fluid level (especially after all the effort you invested to find the tank!).
However, while I'm not a hydraulics expert I have worked on and repaired a lot of hydraulic systems in the past. Typically, low oil level would not result in the problem you describe. In your system, the pump pumps oil through lines into the hydraulic cylinders to extend them. If you have low oil level, and the pump runs out of oil and begins ingesting air before the cylinders are fully extended, they would simply quit extending.
If your cylinders are all extending properly--but later one or more "sinks" that would indicate that there is adequate oil to fully extend the cylinders, but later some oil "leaked out" of one or more cylinders. The leak usually wouldn't be an external one--it would usually be an internal bypass within that cylinder or (more likely) an oil leak back through the valve that closes to "lock" the oil within the cylinder after it is pumped in and hold the cylinder extended. Either fault would allow the cylinders to fully extend normally, but then let one or more sink over time.
Mike
Post by: 2 Frazzled on June 23, 2021, 09:22:20 am
Good info Mike. I guess we need a repair shop that can troubleshoot jacks. We'll add it to the list.
