Main Forum => General Discussion => Topic started by: Tarnold on October 24, 2020, 02:59:26 pm
On a fan with temp. Sensor, does the screen “twist” off or pry off. There is one raised dimple on the plastic frame, but I can’t seem to rotate it either way.
You raise it a bit at the finger hole and work your way around with your other hand. There should be "clips" that snap into the edge.
