Main Forum => General Discussion => Topic started by: rvrunner on January 18, 2020, 10:06:16 am
Look under the slide, there's an opening, a slot with 2 rubber flaps on each side, it's there so the slide can pass by a wiring harness when put in and out, It doesn't seal out the outside. Critters can get inside the rv, mice, spiders, snakes. Is it possible, or has anyone ever rerouted the wires so that opening can be closed up?
