Main Forum => General Discussion => Topic started by: bftownes on March 13, 2019, 08:29:47 am
Title: Accumulator Tank
Post by: bftownes on March 13, 2019, 08:29:47 am
Not wanting to hi-jack a previous thread, I am starting this one.
I have the exact, stainless steel accumulator tank as in the picture Ron posted in another thread.  I had it installed by PC during my build.  I am not sure if it is working properly and will address this when I head to Elkhart for some minor warranty work and questions.
When I first turn on the water pump, it seems to run for a long time, maybe a minute, before shutting down.  I have not experienced this in my previous motorhomes.  When the water is turned on, it is my opinion that the pump is excessively noisy...vibrating.  The tank is under the DS bed, the pump is under the PS bed.  I have had thoughts of having it removed.  I received no user information and a google search has resulted in nothing.
Is this normal?  Should the pump not run smoothly and build proper pressure in 15-20 seconds?
Cheers  :)(:
Barry T
Title: Re: Accumulator Tank
Post by: Ron Dittmer on March 13, 2019, 03:44:30 pm
Hi Barry,
The reason for the excessive noise is because of where Phoenix installed the tank in relation to the pump.  They officially did nothing wrong.  It's only that you gained half of the benefit with their installation.  They likely installed the tank so far from the pump because there was no room to mount the pump and tank together.  The tank needs to be very close to the pump to eliminate most of the pump noise.  Using a flexible hose between pump and tank eliminates the vibration that apparently in your case is getting amplified through the hard plastic PEX plumbing between the two.  The flexible hose is the same kind you would use to hook up a toilet or faucet at home.  I prefer the stainless steel braided type.
My installation shown is odd but it works.  It is extremely difficult to see, but I have a flexible stainless steel braided line between the pump and tank.  The vibration created by the pump is cancelled away through the flexible line and also from the heavy tank.  The hard plastic PEX plumbing after the tank feeding the entire motor home, does not get vibrated.
(https://farm4.staticflickr.com/3630/3507693131_74b69ef2f2_z.jpg?zz=1)
Concerning pump-run-time.  With any accumulator tank, when you run the water and the pump kicks on, the pump is pretty much keeping up with the demand.  If you turn off the water at the time the pump kicks on, the pump will run roughly 20 seconds.  Keep in-mind that I never timed how long it takes for my pump to fill up the accumulator tank if it has been 100% deleted.
When the accumulator tank is 100% empty (at zero plumbing pressure) there has to be a certain PSI inside the tank.  If my memory serves me well, it is between 17-20 PSI.  It should be set to the same pressure that the pump turns on at, whatever that is.  It could be that Phoenix did not set the tank pressure properly, or the air valve is not tight and it lost pressure.  The valve is the same as a car tire, located on the opposite side of the pipe fitting, under a plastic cap.  In my case, under the blue plastic cap on top.
I should re-take the pictures with my Samsung phone.  That picture dates back to 2008, taken with real old digital technology.
Post by: gandalf42 on March 13, 2019, 04:17:43 pm
Actually the accumulator tank can be about anywhere in the system. It creates a reservoir to maintain the water pressure to keep the pump from turning on as frequently as it would otherwise. Less pump running...less pump noise.
The noise in general from the pump itself can be reduced by reducing the vibration impacts. This can be done by using the flex hose on the output or by putting rubber feet or a rubber mat under the pump.
Unfortunately in our 2552 they placed the pump almost directly behind the screen allowing maximum noise to get out. No mitigation of the vibration was made and everything is packed in very tight making change hard.
Post by: Joseph on March 13, 2019, 04:23:12 pm
I installed one myself, 2 gallon, for 50 buck including fittings. I positioned it right above the pump itself by strapping it horizontally to a one by four. I have a 2552 with the twin beds so I don’t know if it’s the same as the 2910 but if it has twin beds the tank can be within 2 feet of the pump. Now when I first installed it I had vibration noise so I installed a piece of rubber between the tank and the mounting board and that cured it. Like Ron mentioned having a flexible hose between the tank and the pump is important in lessoning vibration as well.
Post by: 2 Lucky on March 13, 2019, 08:54:33 pm
Would it be proper to assume that the larger the tank the better? Or will a smaller one do as well...
Post by: Ron Dittmer on March 13, 2019, 09:43:15 pm
I have no experience with a smaller tank.  I can say that our 2 gallon tank "feels right" to both of us.  I would not get anything larger.
Post by: bftownes on March 14, 2019, 08:47:57 am
Hi Barry,
Thanks Ron,  tymote
I have no qualm with Phoenix, but was a little disappointed with the pump noise.  All my motorhome water pumps have had the same noise; I was hoping the accumulator tank would lessen the noise.  I am happy that the pump works!  Before I installed the Oxygenics shower head, we would use the pump for showers.  The pump delivered a strong, consistent water pressure.  The tank takes up a bit of storage and I suppose I could always have it removed.  It's on my short punch list.  Another thing, on my last motorhome, the pump was located outside in the wet bay.  Since the pump is literally under a bed, it's possible that I notice it more.  If it ain't broke, don't fix it.  The cost of the accumulator tank was "minimal".
Cheers  :)(:
Barry T
Post by: Doneworking on March 14, 2019, 12:21:00 pm
First of all, I have never had an accumulator pump.   That being said, I did buy one a few years ago but never got a "round tuit".   I got a little concerned when I read on the information that came with the pump that an accumulator was not needed or recommended.
So-my question is: (1) should I install the accumulator?   (2)What benefits do they really provide?  (3)What are the disadvantages, if any?   (4) How does an accumulator function when you pump the pink stuff into the lines and the water tank for winterizing?  Does it fill with pinkie?
Please educate me.
As to the noise coming from the pump, I have eliminated that to a degree by covering the PEX plumbing in that area with this:
https://www.lowes.com/pd/Frost-King-3-4-in-x-6-ft-Foam-Plumbing-Tubular-Pipe-Insulation/1060005
Unfortunately, on our PC2350 the bed has to be removed to really get to all the pump to really work on stuff.  It can be accessed through a removeable plate in the exterior storage area, but only in a limited way.  SO, I have to take the bedding out and remove all that heavy strand board that is used for a base to the bed.  The pump is installed incorrectly IMO.  It is connected directly to the water tank with PEX and PEX leads directly from the output.   I really need to isolate it with flex tubing to cut down more on the racket.
Paul
Post by: Ron Dittmer on March 14, 2019, 12:51:07 pm
I agree that covering the PEX plumbing with the pre-fab foam insulation tube could offer significant noise reduction.
I also wonder if you connected a length of stainless steel braided line between pump and PEX, spiral it around as shown, place thin carpet padding in-between the layers, just might make it as quiet as ours.  We have to be silent to hear our pump running.
The pump vibrates so badly that when connected directly to the hard PEX, it vibrates the PEX throughout the entire house.  Dampening the vibration right at the pump using a length of stainless steel braided flex may offer the solution.
Coil the braided line like this, then place thin carpet padding in between the layers.  It's worth a try, certainly a very cheap and easy experiment.  Find the braided line with the right fittings at your local home improvement center.
(https://mobileimages.lowes.com/product/converted/091712/091712011828.jpg)
Post by: Volkemon on March 14, 2019, 01:09:33 pm
Please educate me.
Paul
Ok!   :-D
https://www.jabscoshop.com/files/Accumulator%20and%20Expansion%20Tank%20Instructions%20ZPWL4%20doc595.pdf (https://www.jabscoshop.com/files/Accumulator%20and%20Expansion%20Tank%20Instructions%20ZPWL4%20doc595.pdf)
Winterization is covered also near the bottom of the document. (Its written in the King's English, a calorifier is a water heater).
I also have a 2350, and will remove the bed for this mod. I did not think of that, Thanks for the hint.  tymote  (Despite Ron D's generous description, I barely fit in the side compartment.  :lol )
I am assuming the accumulator will act like an expansion tank also, and stop my water heater from dribbling out the pressure relief when it heats. Presently we open the hot water a moment to relieve the pressure, but I prefer not to expose the system to this overpressure condition.
You said you have one, but DIY solutions are there also that may fit an RV better.
http://www.modmyrv.com/2009/06/10/rv-diy-water-accumulator (http://www.modmyrv.com/2009/06/10/rv-diy-water-accumulator)
I did find a few references that said an accumulator should not be used with variable flow/pressure pumps. The DIY link above says its OK.  (WH)  I have a regular pump, so its not a concern to me.
Post by: Ron Dittmer on March 14, 2019, 01:21:15 pm
Oh that is funny.  I assumed everyone knew to remove the bed platform to access the work area.  I am no contortionist myself.  You will find yourself working from the top and also through the side.
You need to make your own decision on this next point.  I was worried about damaging or disturbing everything from stuff tossed into the compartment and being thrashed around while driving, so I made a protective shroud from wood as shown.
 11 years and 35,000 miles since the installation and I have not yet removed the cover.
Mounting the pump on top of the nice $140 stainless steel tank with pump-mount, I think there is less of a concern given the pump would be mounted up near the ceiling instead of mine mounted on the floor.  Note the plastics and wires right where damage could easily occur.
(https://farm4.staticflickr.com/3350/3507693091_85041ecbd7_z.jpg?zz=1)
(https://farm8.staticflickr.com/7908/47379116131_9aa48549c3_z.jpg)
(https://farm8.staticflickr.com/7913/47379116181_a090674c60_z.jpg)
(https://farm8.staticflickr.com/7906/47379116231_4a6f841d80_o.jpg)
Post by: bftownes on March 14, 2019, 04:45:17 pm
Please educate me.
Paul
Doneworking, I had the same question regarding pink and the accumulator tank.  I winterized mine about a month ago and used the video with Earl performing the task.  I had pink running  through all plumbing, including the sanicon and used maybe 1 and 1/2 gallons.  Not sure if pink went into it or not.  I guess I will find out when I dewinterize in the next couple of weeks.
Barry T
Post by: Ron Dittmer on March 14, 2019, 10:22:04 pm
Barry T
Talking about the 2 gallon tanks.  When there is no pressure in the RV plumbing line, there is no water in the tank.
I believe there is some pressure in the tank when sold, referred to as "precharged".  If you look inside the tank where the water line hooks up, you will see a perforated plate just inside the opening and the bladder pressed up against it.  There is no water inside it when there is no RV plumbing pressure because the badder forces everything out.
Make sense?
Post by: bftownes on March 15, 2019, 06:06:49 pm
Barry T
Make sense?
Post by: bftownes on March 15, 2019, 06:08:05 pm
Barry T
Make sense?
Kinda makes sense. :) Thanks again Ron.
Barry T
Post by: BlueBlaze on March 24, 2019, 05:45:15 pm
I really liked that high-dollar stainless tank Ron mentioned, so I ordered it.  Now I'm scratching my head over how best to install it.
It occurred to me that I really don't want to use the integrated pump mount, because that would put the pump much higher than the water inlet.  Doesn't it need a gravity feed to the pump, so it will self-prime?
So I decided to order a female-to-male 1/2" tee, and plumb it between the pump and the output connector, (which was originally connected directly to the pump).  Then, I got a 1/2" nipple for the tank, and I'll use a stainless braided sink hose to connect the accumulator tank to the tee.  The accumulator tank will be bolted to the floor horizontally, so I can access both the pipe connection and the air valve.
One thing that bothers me -- since the tank is mounted horizontally, is there a danger that it will not drain completely for winterizing?  The instruction sheet says it can be mounted in any direction. So does that mean that the bladder will evacuate the tank completely, so that it doesn't have to hang with the plumbing on the bottom?
Oh, and I got a strainer gadget for the input side.
I spent a lot of time puzzling over all the various pipe threads -- "PT" vs "NPT" vs NPSM vs FIP.   The tank says is has a 1/2" FNPT thread.  The strainer (from the same company, Shurflo, sold for motorhome usage, just like the pump and the tank) says it has a NPSM thread.  I think the pump has an "NPT" thread.  All of them 1/2".  I have no idea what type of thread the swivel head on the PEX adapter is, other than it was fastened to the output side of the pump, so I guess that means it's "NPT", or maybe FIP?  The stainless braided sink hose says it has FIP threaded connectors.
From what I've read, NPT and PT are tapered threads, which need teflon tape.  But the NPSM is a NON-tapered thread, which requires a rubber o-ring (which the strainer didn't come with).  The strainer seems to screw onto the input side of the pump OK, but I didn't think you could mix tapered and non-tapered pipe fittings.  The TEE is PT and the nipple is NPT (tapered).  And somewhere I read that FIP is compatible with NPT. So, I THINK this all will work.
If anyone could shed some light on the thread-compatibility issue, that would be helpful.  Otherwise, I guess I'll just screw it all together and pray.  Comments welcome.
Post by: Ron Dittmer on March 25, 2019, 12:01:29 am
I can't help you directly concerning which threads.  I advise to take your pump and tank to a trusted hardware store and pick the brain of an experienced guy there.  Our local Ace Hardware and Home Depot have a couple of well knowledgeable guys.  It's been a long time now but I do recall that being tricky for me as well.  If you look at my pictures, you will see brass fittings and elbows.  I think I had to use brass to get from one type of thread to another.
Regarding the orientation of the tank.  It simply does not matter.  The bladder inside will evacuate 100% of the water when you have zero pressure in the plumbing.  Like my Home Depot tank, if you look inside, you might be able to see the bladder right there at the opening, behind a perforated plate.
Regarding the elevation of the pump to the fresh water tank, you ask a very good question.  I never gave that a thought.  If what you say is true about self-priming, then I wonder why the fancy accumulator tank offers a place to mount the pump up high on top of it.  If that is of concern, I wonder if you could you lay the accumulator tank on the floor, but mount it's feet to a wall so the pump is much closer to the floor.
You are blazing a new trail.
Post by: bftownes on March 25, 2019, 07:06:22 am
Blue Blaze,
That same tank was installed during my build.  I received no instructions/manual (maybe I will send an email to PC).  Could you tell me what the proper air pressure is for the tank?  Is there any way for me to get a copy of the instructions on the internet?  A Google search provided nothing.
Thanks
Barry T
Post by: Ron Dittmer on March 26, 2019, 01:48:30 am
Thanks
Barry T
Hi Barry,
I believe the official rule is that all tanks should be set to 20 psi before installation, or afterward when there is no water pressure in the plumbing system.  A long time ago, I think I read somewhere that the psi should be set to the same psi as the Shurflo pump's "turn-on" water pressure which I think is 20 psi for all such pumps installed in PCs.  Hopefully someone will confirm or correct what I recollect.
Post by: Volkemon on March 26, 2019, 06:10:41 am
Pressure in the tank is to be ~ 2psi less than the cut-in pressure of the water pump.  Thats for home use, I found a manual for the shurflo accumulator tank, it says same as the turn on pressure.
( http://beamalarm.com/Documents/accumulator_tank%20_model_181_installation.html (http://beamalarm.com/Documents/accumulator_tank%20_model_181_installation.html))
Using a low pressure gauge (50 psi max or even less for our use) will allow you more accuracy. Using the 150 psi truck gauge to measure 18 psi is not in its most accurate measuring area. Here is a 20 pound for under $10...  https://www.amazon.com/PRESSURE-GAUGE-VICTOR-MfrPartNo-22-5-00887-8/dp/B000Q7HS8Y/ (https://www.amazon.com/PRESSURE-GAUGE-VICTOR-MfrPartNo-22-5-00887-8/dp/B000Q7HS8Y/)  I prefer a dial type, but these work. There are ~30 psi dial ones available in many bike shops, but will likely cost more.
So, if the water pump turns on at 20PSI in PC's, charge the accumulator to 18.  More pressure than needed will cause the accumulator to store less, and pump to cycle more. Pressure above the cutoff pressure will cause the tank to not do much at all but be a balloon attached to the system.  :lol
To check the air pressure, turn off the pump, and leave a faucet open to ensure there is no water system pressure. Then do your checking and adjusting. Having water pressurized in the system will give false readings.
RE: Threads.. at the pressures we are dealing with, (50 psi max or so)  I would Teflon tape 'em and screw 'em together. Probably what happens when most techs are tasked with installing these. Not like we are dealing with a 3000 psi hydraulic system.  :-D  Free advice, and worth every cent.
Post by: BlueBlaze on March 26, 2019, 08:41:21 pm
On the pressure question, I kind of wonder how you could get it within 2-3 psi without measuring what the pump puts out.  I don't have a way to measure liquid pressure.  But my water hookup regulator is set at 35, so I bet the pump puts out more than 20.  At least, I don't notice a big difference in pressure when it's on tank water.  So I figured I would just over fill the accumulator tank to about 40 and then let the air out slowly until the pump came on.  Then, I'd let out another 3 psi.  Do you think that would work?
Post by: Ron Dittmer on March 26, 2019, 09:58:04 pm
I know what you mean BlueBlaze.  That is why I set my tank 12 years ago at 17 psi.  But that was 12 years ago.  I suppose I should check the psi again, but the system does work well, so I just let it ride.
For setting the psi accurately, I would assume a digital gauge is a better choice for that, considering such a low pressure.
Post by: Volkemon on March 27, 2019, 08:10:27 am
Seems like a good workaround.
I wonder...to determine system pressure could one:
1) open a spigot, depressurize system.
2) let all the air out of the accumulator tank.
(Now both bladder and system are at '0' psi)
3) turn on pump, allow to pressurize system
4) measure air pressure in bladder
I am thinking that if the system is at 20PSI, it will compress the bladder until it matches pressure.
Regarding accuracy of gauges... I would be inclined to think the range of the gauge would have the most influence on the accuracy.
IE: If you have a 150 PSI max gauge, it is most accurate from 40-120 psi, with accuracy faltering the closer one gets to the ends of the range. So measuring 17 psi with that gauge may not be as accurate.  A gauge with a 30 psi range would be ideal for measuring the 10-20 psi range.
Ever wonder why cars used to come with a 120 MPH speedo when there was no where one could drive that fast? It was because having that range meant the gauge was much more accurate in the 'useful' range of 20-80.  (Now this was also when speedo's were cable drivin, and relied on spinning magnets and dampening springs.... little different today.   :-D )
Post by: RVCamping on March 27, 2019, 09:20:23 am
Ron - these are the gauges https://www.ghmeiser.com/dial-gauges.htm I use on my racing bikes which require very low tire pressures. I have one 0-15 lbs. and another 0-30 lbs. Very accurate and both have bleeder valves to allow an easy way to achieve accurate pressures. you pump a little over the recommended pressure and bleed off the air to the correct pressure while watching the gauge.  Mine are designed for Presta (European) valves but they are also available in Schrader valves which is the standard valve stem on most American equipment, cars and trucks. Schrader is what you need to read the pressure of accumulator tanks. BTW I had PC install the 2 gallon Sur-flo stainless steel model in our 2552 and it has worked very well. - Dick
Post by: Joseph on March 27, 2019, 11:08:12 am
Over thinking it, there is no need to buy any expensive or special pressure gauge. I use a bicycle pump. I pumped it up to 25 and called it good. Growing up with Wells we used cheap pocket gauges and never gave it a second thought.
Post by: Ron Dittmer on March 28, 2019, 09:30:35 am
You may find reading my experience on the tire gauges I owned.  CLICK HERE (http://forum.phoenixusarv.com/index.php/topic,2798.0.html) to read my post with pictures.
Post by: Joseph on March 28, 2019, 11:22:36 am
Ron, I know they can be off however the issue of air pressure in the tank is the same. It’s not an exact science, it doesn’t have to be exactly 20 psi or 30 psi etc.  with tires you want to have a fairly accurate gauge but even then people over think it.
Post by: BlueBlaze on March 30, 2019, 06:39:45 pm
Well, I thought I ought to give an update on my accumulator tank project.
The original plan didn't work.  I thought I could just put a female-to-male brass tee between the pump and the output line, and then run a braided flexible sink hose to the accumulator tank.  I tried everything I could think of to get a water-tight seal on the pump's male plastic output connector, but the only thing that worked was a PEX connector.  The female side of the brass tee just bottomed out before it got tight enough to seal, regardless of whether I used teflon tape or pipe dope.  Even the 1/2" FIP connector on the braided sink hose wouldn't seal on that connector, and it has a sealing washer.  I don't know what the deal is with that connector.
So I gave up on slick 'n easy and did it with PEX connectors instead.  In order to get enough room, I had to turn the pump 90 degrees.  Then I used a 90 degree 1/2" female ell connector coming out of the pump, going straight into a tee, and then into a male 1/2" connector for the output line.  I used another male 1/2" connector coming out of the side of the tee, so I could attach a short 12" braided flex line to the accumulator tank.
This was my first experience with PEX plumbing, and I was shocked at the price they were asking for the tool to crimp the cinch rings.  It occurred to me that a pair of tile nippers might work, and since I had a pair, I gave it a try.  I really had to put some muscle into it to get a crimp that looked like the pictures on-line, but it worked fine.
Regarding the pressure adjustment, the idea I mentioned earlier also worked fine.  The pump says it puts out 45 PSI, though, so I had to pressurize the tank to 50 lbs, to get started.   I used my little "Slime" electronic tire gauge to slowly let the air out until the pump came on.  When I checked the pressure, sure enough, it was 45 pounds.  So I let another squirt out, and left it at that.
It surprised me how long the pump ran to fill the tank, once it came on.  I was also amazed at how long the water ran from the kitchen faucet before the pump came back on -- at least a couple of minutes.  The tank cured the water hammer noise, but even without all the water hammer going on, that pump is just plain noisy!
While I was working on all this, I noticed that the paneling on the side of the trunk (between the trunk and the water tank) was crushed at the bottom.  No wonder -- that little 1/8" sheet of fake wood paneling was the only thing supporting the middle of the bed!  So I added a 2x4 brace and straightened out the paneling with a few more staples.
The final problem was what to do with the sub-woofer.  I had to move it to make room for the tank.  Now, why the sub-woofer for the "Executive" surround-sound system is installed in the trunk under the bed shall forever remain a mystery.  I can't imagine that much bass actually makes it back into the house from under a mattress!   I was tempted to just remove it, but then it occurred to me that if I put it on top of the accumulator tank, it might shield luggage and stuff from banging against the pump.  Besides -- it gave me a chance to use that fancy pump mount on the top of that $150 accumulator tank!
So anyway, that's the story.  Would I do it again?  Nope.
Post by: Ron Dittmer on March 30, 2019, 07:52:27 pm
Hi Blue Blaze,
At running the risk of sounding like a critic, I would like to share my thoughts on your installation.  Please take this constructively.
The reason why your pump noise is just as loud as it was before is that you did not isolate the vibration of the pump from the rest of the RV plumbing.  You hard-plumbed it just like it was before, hence the vibration remains amplified just like before.
The addition of the accumulator tank was installed in a manner that makes it completely ineffective in absorbing any pump vibration.  You want the hard PEX from the RV going first to the tank via hard or soft-plumbed using a stainless steel flex hose, then soft-plumbed from there to the pump.  Then the vibration from the pump gets neutralized primarily through the flex hose, and further reduced through the mass of the accumulator tank.  The point of connection to the RV plumbing would then see no vibration at all, reducing the sound to a quiet hum.
I realize you had to improvise given your particular arrangement of components, but your installation does not address any noise, only water pressure regulation.
Regarding the psi you set the tank at, I always thought ~20psi was recommended, not 45 psi.  I am surprised it works as well as you describe.
I am surely no expert on all this.  I only share my thoughts and experience with our PC with a generic 2 gallon accumulator tank.
As far as the subwoofer is concerned, I agree with your thoughts on that.  Because our rig was special-ordered, I requested the subwoofer be installed in the front dinette bench seat.  That worked out very well for us.  The sub is big and it shares the space inside the front dinette bench seat with the generator's power transfer switch.  I use the balance of the compartment for all of my heaviest items like tools & extra 30amp power cords and such, done so to place as much weight as forward as possible.
Post by: BlueBlaze on March 31, 2019, 10:05:10 am
Ron, I actually tried it that way, when the brass TEE idea didn't work.  I bought a 2nd flex hose and attached it directly to the output side and moved the tee to the accumulator tank.  That's when I discovered that even a FIP connector leaks when attached to that pump output male connection.  It also didn't do anything about the pump noise, although it did solve the water hammer noise -- the same as the way it's connected now.
I'm pretty sure the water doesn't have to be directed directly into the tank to solve water hammer.  I'm no plumber, either, but I think my house may be proof of the theory.  It's plumbed with CPVC, and in the attic there is a capped-off pipe extending into the air, near every drop.  The trapped air in the pipe acts as a spring to relieve water hammer (just like the bladder in an accumulator tank).  I think they must do that with CPVC because it's fragile enough to be damaged by water hammer.  But that pipe is not inline with the flow.  It's perpendicular to the change in direction.
Regarding 20 lbs, if your pump turns on at 45 like mine, I don't see how 20 lbs of pressure would work very well.  Seems like it would only use a little water out of the tank before the pressure dropped low enough for the pump to kick on again.  Just theorizing, but with the tank pressure set near the pump turn-on pressure, it should use nearly all of the 2 gallons in the tank before the pump kicks back on, which would maximize the value of having the tank.  I'm not sure where you saw that it should be set at 20.  This tank I bought merely had a warning that the pressure should be maintained at 20 for storage purposes.  Just guessing, but I think that's probably to prevent the bladder from sticking to itself and causing deterioration while the tank is sitting on a shelf waiting to be sold.
Post by: Ron Dittmer on March 31, 2019, 05:31:11 pm
I understand your dilemma about the fittings forcing you to be creative as you have.  I only wished something else could have worked for you to reduce pump vibration throughout your rig, as it did with my setup.
About 20 psi or 45 psi.....45 psi works for you and 20 psi works for me.  I might have actually set mine to 17 psi.  It would be interesting to try the water system at each setting to compare the behaviors.  I also wonder if set at 20 psi might reduce some additional vibration for me because that stores more water in my tank for more vibration cancellation.
Post by: Volkemon on April 09, 2019, 12:16:03 pm
You nailed it. For those still wondering WHAT it all means..
The pressure the tank is at is set when the system is a '0' psi. Pressure up the system to 40 PSI, and you will find the tank pressure has increased also, up to your shutoff pressure. The water stored decreases the air volume in the accumulator, raisng the pressure on the trapped air.
My pump turns OFF at ~40 psi, (pretty sure... have yet to put a gauge on it, but thats stock setting) not 'on' as you state above. If yours turns on at 45, what is your 'off' pressure?!?
In my system, with 20 'on' and 40 psi 'off pressures, if I put the pre-pressure on the tank to 45 psi it would hold no water, as the pump would have to go above shut off to fill the accumulator.
 Likewise, should the pressure be set below turn on pressure, it will reduce the amount of water the accumulator dispenses before the pump cuts back on. It will be 'full' , sure, but not have the pressure in the bladder to deliver that water.
 Having the pressure set at slightly lower than shutoff delivers maximum volume from the tank, and minimum pump cycling.  Some may call this overthinking, others may call it understanding the operating concept to ensure peak efficiency.  (WH) Like the AC techs that charge the system to 'cold as a beer can' on the inlet side, no need to overthink it with all the wet bulb and temperature drop readings stuff...  they dont pay the electric bill on your house.  :beg  We have a name for those techs here- FORMER employees.  :lol
Post by: BlueBlaze on April 12, 2019, 05:54:04 pm
Well, I'm not sure I understood all that, but whatever I did seems to work.  If I run the sink until it comes on, it runs for about another 2 minutes after I turn off the water, which I presume is the time it takes to fill a two gallon tank.  Then, if I turn the faucet back on, the water will run for about two minutes before the pump comes back on.  It would be interesting to see how much water that is, but I didn't think about measuring it when I had it all set up.  I bet it's two gallons, though.
