Main Forum => General Discussion => Topic started by: swiftboot on October 09, 2018, 12:00:50 pm
Title: Leaking drain valve
Post by: swiftboot on October 09, 2018, 12:00:50 pm
There are three water drain valves just forward of and accessible from the right rear storage bin.  The most in-board of the three has a continuous drip drip drip after closing the valve.  I had drained the system, closed the three valves and refilled the tank for planned trip.  These three valves are operated by pulling up to drain and of course pushing down to close.  I suspect the rubber washer (for lack of another word) needs replacing or repaired.  There appears to be a metal clip holding the push/pull valve in place.  Question is would this be proper way to remove the valve to repair?  Secondly, what does the in-board valve drain in the system?  Is there a schematic of these valves available?   I would appreciate any and all advice.  Thanks, Larry
