Main Forum => General Discussion => Topic started by: lamovitz on August 04, 2018, 01:45:36 pm
Title: EEZ Tire Pressure Monitor system wiring question
Post by: lamovitz on August 04, 2018, 01:45:36 pm
Bought the EEZ tire pressure monitor system and its easy to use and seems to work great.  Nice knowing no problems with tire pressure when on the road.  A bit pricey but worth it.  The system does not consistantly show the toad tire pressure so i bought the repeater/extender.  They say to simply wire to a 12 volt source in the back of the rv that will work while driving.  This may be a stupid question but where would that be?  I am assuming maybe the back ceiling light?  Is that in fact 12 volt (we have the led lights on ceiling) that is live while driving?  Or perhaps one of the two small lights over the bed in the back? (We have a 2910T).  If there is someone good with electrical that could answer this it would be greatly appreciated.
Lou Movitz
Title: Re: EEZ Tire Pressure Monitor system wiring question
Post by: fandj on August 04, 2018, 04:54:03 pm
The lights over the beds in our 2016 2552 are 12 volts.  I wired an outlet for phone charging into this light circuit.
Post by: lamovitz on August 04, 2018, 05:15:26 pm
Perfect thanks!
Post by: lamovitz on August 09, 2018, 12:16:17 pm
FYI EEZ tech said ok to wire to 12 volt light in back.  Although it will always be on its minimal draw.  Or on one wire put a toggle switch or quick disconnect to turn off when not traveling.
