Main Forum => General Discussion => Topic started by: Funseekers on December 17, 2017, 11:12:39 pm
Title: Macerator pump
Post by: Funseekers on December 17, 2017, 11:12:39 pm
On my new 2018 pc 2100, tried to turn macerate pump on after opening valve and...nothing.  No sound like it's jammed or some other glitch...just nothing.  Tried to locate fuse under fridge but couldn't seem to locate that particular one....anyone have any idea what I am experiencing?
Title: Re: Macerator pump
Post by: keelhauler on December 18, 2017, 08:45:36 am
First thing to do is to take off shield to get at screw slot. Make sure it turns both ways. Try again.
A small thing can jam and it will not make a noise. Turning usually frees it up.
It uses a circuit breaker, no fuse
Post by: Funseekers on December 18, 2017, 09:46:19 am
Thank you, I'll give that a try and hope it's something simple...it has worked fine up to now.
Post by: Ron Dittmer on December 18, 2017, 10:34:17 pm
Yep, keelhauler has the right advise.
Make sure to put only #1, #2, and toilet paper down the toilet.  No feminine napkins or other items because they will jam the macerator but good.  You don't want to be cleaning it out by hand.  A guest/visitor might not understand the reason for the rules.  Make sure they understand and follow them.  Also provide them a friendly-use garbage can in the bathroom.
Post by: Funseekers on December 21, 2017, 12:58:45 am
Update...turns out the pump froze.....literally!  Had a flash freeze in Nor Cal and wasn't aware this could happen.  Live and learn.  Thanks to all who responded.
Post by: jimmer on December 21, 2017, 01:53:07 pm
Funseekers,  glad it was something easy and hopefully no  damage done.      When I winterize, here in Michigan,  I allow some of the antifreeze that I put into the tanks to go to the pump
by opening the black or gray dump valve briefly.
jim
