Main Forum => Tips and Tricks => Topic started by: campman1 on November 01, 2010, 05:27:48 pm
My Sewage Pump quite in the middle of a dump. Before I contact Factory can anyone tell me where the Fuse is for pump on a 2010 Sprinter 2350? Thanks. Ron
Your macerator pump may be jammed. Take the cap off the motor side. With a large screw driver, see if you turn the motorshaft. If it doesn't turn, the pump is jammed. Try turning it with more pressure, back and forth. Hopefully, that should free it.
I don't know where the fuses are.
Good luck!
