Main Forum => General Discussion => Topic started by: swiftboot on March 19, 2017, 10:49:17 am
Getting ready to dewinterize. Just checking if anyone sees any potential problem in using potable water in the same way we pump the pink antifreeze through the water lines when winterizing. This would clear out the pink, afterward, then pump diluted bleach water through the lines and let stand overnight to sanitize. At same time add diluted bleach water to fresh water tank (1/3 tank), drive around for sloshing effect. Afterwards drain fresh water tank, fill with fresh water and run pump to clear all lines of bleach water. When satisfied with clearing lines of bleach water, open the valve to hot water heater for normal operation. I suspect filling the fresh tank with bleach water and pumping it through the system might have the same results but require the pump to run for a longer period of time. Any suggestions appreciated.
Larry
I put Clorox into the fresh water tank with some fresh water. I drive a short distance and return home. Then I turn on the water pump. I open the farthest valve from the tank and let it run until it turn clear. Both cold and hot. Then I do the other valves until they run clear. I let it sit for about one hour or so. I drain all the lines and the fresh water tank. I fill and drain the water tank a couple more times until I can't smell the Clorox. Then one more fill. Finally I pump fresh water though the lines until I don't smell anything at each valve. The last thing I do is open the water heater bypass, pump water into it and turn it on. I feel the hot water will kill any thing growing in the heater tank. Now I am ready to clean other things before having a cold one and saying "job well done".
Thanks Tom, I believe I was overthinking the procedure, your suggestions are much simpler and just as effective.
One thing I do a bit different is add the bleach "First" into the fresh water tank, then fill to capacity with fresh water, to the point the solution is shooting out the vent hole. This way the bleach gets well stirred-in and I maximize the submersion of bleach on the inner walls of the tank.
I realize you hope the driving will splash the solution high enough, but I prefer to flood it up as high as possible. I do like your idea of driving around and do some quick left/right maneuvers to slosh it higher yet. That surely would be most effective at full coverage. With a full tank dripping out the vent hole, just be careful of the bleach solution leaking and then getting air born hitting people and cars around you. Maybe drive slow down the center of your street in your neighborhood with nothing around to get hit. I have a stretch of road in my neighborhood perfect for that.
Just my 2 cents, but if you drain the fresh water tank before storage, the only place mold could grow is the bottom if the tank where thst last bit of water didn't drain out. I also blow the lines out till no more water comes out and let them sit all winter. I do us RV antifreeze in all traps and over do that so there' some antifreeze in the waste tanks. Works for me in Colorado.
In place of RV antifreeze in the traps you can use windshield washer fluid. It is generally cheaper and you still get protection down to -20. If you are using RV antifreeze in the lines, you are already putting some in the traps. Just saying.
I thought that mold could grow any where it is damp not just in standing water. If there is standing water in the tank, can't the mold grow on the sides and top of the tank?
I drain the pink stuff out completely, put a couple of gallons of water in the tank and then pump it through all the faucets. Then, I do like Ron. I put a couple of cups of bleach in the tank and then fill it up to the rim with the hose turned on full to force as much water as fast as possible down into the tank to agitate the bleach and water together. Then, I pump some of this solution through every faucet, shut off the pump and leave the bleach solution in there overnight or sometimes even a little longer. Then, I drain it out completely with the three drain valves. Then, refill with fresh water and off I am done.
Unlike Tom, I open the hot water heater bypass valve and fill that tank also with the bleach solution. By the way, when bypassed and winterized, I leave the drain plug in the tank out of the tank all winter. Also, I use a wand made for the purpose to thoroughly wash out the tank prior to refilling in the spring. Now, with the PC aluminum tanks that don't have an anode like the older tanks this is not so much necessary. In my other rigs over the years, I left the anode out all winter and I rinsed it at the end and beginning of the camping season with the wand sprayer.
I will add further that we do not drink water out of the PC system. We buy and carry bottled water replenishing it as we use it. Just got into that habit over thirty years ago and that is we do. Some of the places we go the water may or may not be to peachy and we figure why take a chance for less than a buck a gallon for generic water from the grocery store.
Pau l
You can flush out the hot water tank by removing the drain plug, connecting to city water, and turning on the city water supply. I will be adding this step to my de-winter procedure this Spring.
I did not think of that, but it sounds like a great substitute. Is there any concern that the -20 blue or -35 purple windshield washer fluid will stain an RV sink?
Around where we live, we have Menard's home improvement centers. I have seen in the fall, Menard's will sometimes run a sale where the RV pink anti-freeze is free after rebate.....something for some of you to watch out for.
Off the subject, I know, but RON, glad to see you sprung for a new picture. My eye was always pulled to that " pole " you had going through your head !!!
It was actually the roof of a golf cart behind my head. It did look like a rod going through my skull :)
The new picture, Irene took of me at home 4 weeks ago, used on my contractor's badge. I am back working at the company that retired me. It seems the company sent too much engineering work to Malaysia too quickly. 3 weeks to-date and some weeks to a few months more and I'll be retired again. My earnings will make for some "extra" traveling money. My mindset is so much better, still giving the job my all, but it works so well in my head. I can't wait to get back into retirement for so many reasons, but especially to get back to watching our 20 month old grand daughter on Fridays. That has been hardest on me.
Okay, sorry for the change in the topic here. Now back to your regularly scheduled program.
Good for you on all accounts ! Sounds like the best of both worlds !
ditto above.
I don't use RV antifreeze in the lines, I blow the water out.
Just MY opinion, but no, mold cannot grow on the top and sides of the water tank just because there's a little bit of water in the bottom of the tank. Besides the fact the sides and top wouldn't be damp, plus there's no food source.
Again.. Just my opinion and experience.. I am NO expert on mold.
And thid:
WHAT DOES MOLD EAT?
Mold cannot produce their own food, thus they are parasitic in nature. Molds get food by absorbing minerals, sugars and water from the plants, soil, animals or decaying matter upon which they live.
Thanks for clearing that up about the mold.
And thid:
WHAT DOES MOLD EAT?
This sounds good and logical but in reality, I have a semi-opaque jug of boiled water I keep on the counter for the dogs (elderly, finicky stomachs) and I have to wash it out periodically because the top and sides (above the water line) get slimy. I don't know what it is but something that I don't want to consume is growing there.
As I said, I am certainly not an expert, or even close, on mold; but, I don't believe boiling water does anything but kill whatever is alive in the water. I don't believe it removes any "food for mold" in the water. Also, a half or more filled jug isn't the same environment as a closed 40+ gallon tank with a few cups of water left in it that is in an RV parked in one spot over the winter.
But I certainly could be wrong.
