Main Forum => General Discussion => Topic started by: BarbRN on June 12, 2013, 09:35:53 am
Anybody get the angle and height fixed on their arm rests? they are way to high for both of us. Trying to think of a remedy. Our last rig had adjustments that were nice but just a permanent lowering would be perfect.
I don't believe they are adjustable. I think you can remove them by pushing in hard at the pivot point while turning past the stop in the "UP" position. I would remove one and see if it can be adjusted once taken off. Maybe you can adjust the angle, but surely not the height.
A good seat cushion would be the next consideration. Just make sure you can still reach the pedals. :)
If all is hopeless, you might be able to purchase off-set or adjustable armrests from the OEM supplier. For our 2007 it was http://www.paulsseating.com/ (http://www.paulsseating.com/) Do you have the original seat tags? PC-USA can help with your seat supplier. Those armrests are not expensive. They cost me $20 a piece (or was it for the pair?) when I ordered my 3rd captain seat by the entry door. Keep in-mind that offset armrests would stick out forward when folded upward.
Barb:
I agree that the arms rests need to be adjustable; not sure there is much that can be done with the set up we all currently have...Paul's Seating (supplier of seats to PC) needs to offer such a feature. Ron
Like a said, Pauls Seating might offer adjustable ones that fit the same socket.
