I bought a conventional sewer hose storage tube maybe 6 years ago from Camping World. I wanted to carry a back-up manual sewer hose in-case our macerator failed during a trip. I finally got around to mounting it. Unfortunately our 2007 2350 did not provide a good means to mount the tube in the ideal location with easy access from the dump-side of the rig. A waste tank hangs some inches low right behind the macerator panel. I mounted the tube with access from the passenger side instead to mount the tube as high as possible. The main gas tank hangs lower so I feel I am in good shape.
The
RHINO SEWER HOSE KIT fits perfectly inside it. Walmart sells the Rhino kit in their stores, discounting them in the fall to half price or less.
The tube is fairly out of sight from normal views of the rig.
Trivia Question: See the little hook hanging on the left side? Why did I add it?
Visually this looks like an interference problem, but the door swings open completely and the hose kit removes just fine.
The tube is mounted right behind the main gas tank as shown. Mounting the tube high to the frame, I added a self-stick rubber pad in one spot where the round tube contacts the frame, added to prevent abbrasion. You can barely see the protective pad.
The tube gently presses against the insulation of the waste tank.
The driver side mount, there are OEM holes in the Ford frame that I utilized. They were perfect.
On the passenger side, I whipped up a pair of straps that worked out great.
